[GRASS-QA] GRASS QA: glynn | ./grass6/visualization/xganim/main.c
|no clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 28 17:01:25 EDT 2006
Hello glynn,
ANALYSIS
visualization/xganim/main.c functions
main (Begins at: 69 Ends at: 267)
Complexity: | 11 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 47 | * | |
LOC: | 199 | ** | Warning |
at least 1 values are close to an outlier please consider revising code
load_files (Begins at: 270 Ends at: 403)
Complexity: | 13 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 43 | * | |
LOC: | 134 | * | |
metrics are OK
do_run (Begins at: 407 Ends at: 489)
Complexity: | 14 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 83 | | OK |
metrics are OK
gee_wildfiles (Begins at: 493 Ends at: 537)
Complexity: | 8 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 45 | | OK |
metrics are OK
change_label (Begins at: 543 Ends at: 552)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
parse_command (Begins at: 556 Ends at: 601)
Complexity: | 4 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 13 | | OK |
LOC: | 46 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
