[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.grow2/main.c |no clones | 0 monsters | 3 warnings
Sat Oct 28 17:31:46 EDT 2006
Hello glynn,
ANALYSIS
raster/r.grow2/main.c functions
distance_euclidian_squared (Begins at: 35 Ends at: 38)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
distance_maximum (Begins at: 40 Ends at: 43)
CalledNBR:    |       4 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
distance_manhattan (Begins at: 45 Ends at: 48)
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
setup_neighbors (Begins at: 50 Ends at: 78)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
setup_neighbors_euclidian (Begins at: 80 Ends at: 85)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
setup_neighbors_maximum (Begins at: 87 Ends at: 90)
LOC:          |       4 |       |      OK |
metrics are OK
setup_neighbors_manhattan (Begins at: 92 Ends at: 95)
LOC:          |       4 |       |      OK |
metrics are OK
main (Begins at: 97 Ends at: 316)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     220 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
