[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.rast.arrow/arrow.c |no clones | 3 monsters | 0 warnings
Sat Oct 28 17:50:18 EDT 2006
Hello glynn,
ANALYSIS
display/d.rast.arrow/arrow.c functions
main (Begins at: 73 Ends at: 598)
Complexity:   |      72 |   *** | MONSTER |
CalledNBR:    |     173 |   *** | MONSTER |
LOC:          |     526 |   *** | MONSTER |
3 metric are OUT OF RANGE!
arrow_mag (Begins at: 605 Ends at: 638)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
arrow_360 (Begins at: 641 Ends at: 679)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
arrow_se (Begins at: 681 Ends at: 696)
CalledNBR:    |       6 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
arrow_ne (Begins at: 698 Ends at: 713)
LOC:          |      16 |       |      OK |
metrics are OK
arrow_nw (Begins at: 715 Ends at: 730)
LOC:          |      16 |       |      OK |
metrics are OK
arrow_sw (Begins at: 732 Ends at: 747)
LOC:          |      16 |       |      OK |
metrics are OK
arrow_e (Begins at: 748 Ends at: 763)
LOC:          |      16 |       |      OK |
metrics are OK
arrow_w (Begins at: 764 Ends at: 779)
LOC:          |      16 |       |      OK |
metrics are OK
arrow_s (Begins at: 780 Ends at: 795)
LOC:          |      16 |       |      OK |
metrics are OK
arrow_n (Begins at: 796 Ends at: 811)
LOC:          |      16 |       |      OK |
metrics are OK
draw_x (Begins at: 812 Ends at: 825)
CalledNBR:    |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
unknown_ (Begins at: 826 Ends at: 845)
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
