[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.out.mat/main.c |no clones | 2 monsters | 0 warnings
Sat Oct 28 17:50:19 EDT 2006
Hello glynn,
ANALYSIS
raster/r.out.mat/main.c functions
main (Begins at: 22 Ends at: 391)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |     120 |   *** | MONSTER |
LOC:          |     370 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
