[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.out.vtk/main.c |no clones | 0 monsters | 3 warnings
Sat Oct 28 17:50:19 EDT 2006
Hello glynn,
ANALYSIS
raster/r.out.vtk/main.c functions
check_input_maps (Begins at: 37 Ends at: 123)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      87 |       |      OK |
metrics are OK
main (Begins at: 129 Ends at: 386)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |      73 |    ** | Warning |
LOC:          |     258 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
