[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.fill.dir/main.c |no
clones | 1 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 28 17:50:18 EDT 2006
Hello glynn,
ANALYSIS
raster/r.fill.dir/main.c functions
main (Begins at: 58 Ends at: 292)
Complexity: | 15 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 108 | *** | MONSTER |
LOC: | 235 | ** | Warning |
1 metric are OUT OF RANGE!
dir_type (Begins at: 294 Ends at: 333)
Complexity: | 27 | ** | Warning |
CalledNBR: | 0 | | OK |
LOC: | 40 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
