[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.topidx/file_io.c |no clones | 0 monsters | 0 warnings
Sat Oct 28 17:50:19 EDT 2006
Hello glynn,
ANALYSIS
raster/r.topidx/file_io.c functions
getcells (Begins at: 9 Ends at: 75)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
putcells (Begins at: 79 Ends at: 101)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
