[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.walk/main.c |1 clones ( main.c main.c )| 3 monsters | 0 warnings
Sat Oct 28 17:50:20 EDT 2006
Hello glynn,
ANALYSIS
raster/r.walk/main.c functions
main (Begins at: 81 Ends at: 1511)
Complexity:   |     196 |   *** | MONSTER |
CalledNBR:    |     410 |   *** | MONSTER |
LOC:          |    1431 |   *** | MONSTER |
3 metric are OUT OF RANGE!
process_answers (Begins at: 1517 Ends at: 1566)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
time_to_stop (Begins at: 1571 Ends at: 1591)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  time_to_stop
In raster/r.walk/main.c clones of  time_to_stop are:
	raster/r.cost/main.c  time_to_stop
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
