[GRASS-QA] GRASS QA: hamish | ./grass6/paint/p.out.vrml/main.c |no clones | 0 monsters | 0 warnings
Sun Oct 29 09:31:58 EST 2006
Hello hamish,
ANALYSIS
paint/p.out.vrml/main.c functions
main (Begins at: 13 Ends at: 178)
Complexity:   |      16 |     * |         |
CalledNBR:    |      55 |     * |         |
LOC:          |     166 |     * |         |
metrics are OK
init_coordcnv (Begins at: 204 Ends at: 227)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
do_coordcnv (Begins at: 230 Ends at: 254)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-29 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
