[GRASS-QA] GRASS QA: hamish | ./grass6/paint/p.out.vrml/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Oct 29 11:30:15 EST 2006
Hello hamish,
ANALYSIS
paint/p.out.vrml/main.c functions
main (Begins at: 13 Ends at: 178)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 55 | * | |
LOC: | 166 | * | |
metrics are OK
init_coordcnv (Begins at: 204 Ends at: 227)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 24 | | OK |
metrics are OK
do_coordcnv (Begins at: 230 Ends at: 254)
Complexity: | 9 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 25 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
