[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.resamp.stats/main.c |1 clones ( main.c )| 0 monsters | 1 warnings
Sun Oct 29 23:34:50 EST 2006
Hello hamish,
ANALYSIS
raster/r.resamp.stats/main.c functions
build_method_list (Begins at: 28 Ends at: 45)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
find_method (Begins at: 47 Ends at: 56)
LOC:          |      10 |       |      OK |
metrics are OK
resamp_unweighted (Begins at: 66 Ends at: 138)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      73 |       |      OK |
metrics are OK
resamp_weighted (Begins at: 140 Ends at: 229)
CalledNBR:    |      20 |       |      OK |
LOC:          |      90 |       |      OK |
metrics are OK
main (Begins at: 231 Ends at: 372)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      72 |    ** | Warning |
LOC:          |     142 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
  build_method_list
In raster/r.resamp.stats/main.c clones of  build_method_list are:
	raster/r.series/main.c  build_method_list
Threshold GRASS6 key metrics values at 2006-10-29 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
