[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.distance/parse.c |no clones | 0 monsters | 0 warnings
Tue Oct 31 11:08:24 EST 2006
Hello jachym,
ANALYSIS
raster/r.distance/parse.c functions
parse (Begins at: 25 Ends at: 92)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-31 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
