[GRASS-QA] GRASS QA: cho | ./grass6/lib/raster/com_io.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 1 05:29:05 EDT 2006
Hello cho,
ANALYSIS
lib/raster/com_io.c functions
init_transport (Begins at: 168 Ends at: 186)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
R_open_driver (Begins at: 188 Ends at: 192)
Complexity: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
R__open_quiet (Begins at: 194 Ends at: 198)
LOC: | 5 | | OK |
metrics are OK
R_stabilize (Begins at: 200 Ends at: 203)
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
R_kill_driver (Begins at: 205 Ends at: 208)
LOC: | 4 | | OK |
metrics are OK
R_close_driver (Begins at: 210 Ends at: 215)
LOC: | 6 | | OK |
metrics are OK
R_release_driver (Begins at: 217 Ends at: 220)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
