[GRASS-QA] GRASS QA: cho | ./grass6/display/d.text.new/main.c |no
clones | 4 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 1 06:26:19 EDT 2006
Hello cho,
ANALYSIS
display/d.text.new/main.c functions
main (Begins at: 76 Ends at: 533)
Complexity: | 60 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 132 | *** | MONSTER |
LOC: | 458 | *** | MONSTER |
3 metric are OUT OF RANGE!
set_color (Begins at: 535 Ends at: 559)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 25 | | OK |
metrics are OK
get_coordinates (Begins at: 562 Ends at: 610)
Complexity: | 8 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 17 | | OK |
LOC: | 49 | | OK |
1 metric are OUT OF RANGE!
draw_text (Begins at: 612 Ends at: 687)
Complexity: | 15 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 12 | | OK |
LOC: | 76 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
