[GRASS-QA] GRASS QA: brad | ./grass6/display/d.text.new/main.c |no clones | 4 monsters | 1 warnings
Fri Sep 1 07:31:16 EDT 2006
Hello brad,
ANALYSIS
display/d.text.new/main.c functions
main (Begins at: 78 Ends at: 535)
Complexity:   |      60 |   *** | MONSTER |
CalledNBR:    |     132 |   *** | MONSTER |
LOC:          |     458 |   *** | MONSTER |
3 metric are OUT OF RANGE!
set_color (Begins at: 537 Ends at: 561)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
get_coordinates (Begins at: 564 Ends at: 612)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      17 |       |      OK |
LOC:          |      49 |       |      OK |
1 metric are OUT OF RANGE!
draw_text (Begins at: 614 Ends at: 689)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      12 |       |      OK |
LOC:          |      76 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
