[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.font/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 1 14:29:35 EDT 2006
Hello glynn,
ANALYSIS
display/d.font/main.c functions
main (Begins at: 13 Ends at: 120)
Complexity: | 14 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 41 | * | |
LOC: | 108 | | OK |
metrics are OK
read_ftcap (Begins at: 123 Ends at: 181)
Complexity: | 10 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 59 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
