[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Font.c |no clones | 0 monsters | 0 warnings
Fri Sep 1 18:42:39 EDT 2006
Hello glynn,
ANALYSIS
lib/driver/Font.c functions
COM_Font_stroke_get (Begins at: 13 Ends at: 17)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
COM_Font_freetype_get (Begins at: 19 Ends at: 23)
LOC:          |       5 |       |      OK |
metrics are OK
COM_Font_get (Begins at: 25 Ends at: 60)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
COM_Font_freetype_release (Begins at: 62 Ends at: 64)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       3 |       |      OK |
metrics are OK
COM_Font_init_charset (Begins at: 66 Ends at: 69)
LOC:          |       4 |       |      OK |
metrics are OK
font_is_freetype (Begins at: 71 Ends at: 74)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
