[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.vect/topo.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 1 19:28:38 EDT 2006
Hello glynn,
ANALYSIS
display/d.vect/topo.c functions
topo (Begins at: 8 Ends at: 178)
Complexity: | 22 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 49 | * | |
LOC: | 171 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
