[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_get.c |no clones | 0 monsters | 0 warnings
Fri Sep 1 19:28:38 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/com_get.c functions
R_get_location_with_box (Begins at: 7 Ends at: 10)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
R_get_location_with_box_old (Begins at: 12 Ends at: 15)
LOC:          |       4 |       |      OK |
metrics are OK
R_get_location_with_line (Begins at: 17 Ends at: 20)
LOC:          |       4 |       |      OK |
metrics are OK
R_get_location_with_line_old (Begins at: 22 Ends at: 25)
LOC:          |       4 |       |      OK |
metrics are OK
R_get_location_with_pointer (Begins at: 27 Ends at: 30)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
R_get_location_with_pointer_old (Begins at: 32 Ends at: 35)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
