[GRASS-QA] GRASS QA: cho | ./grass6/lib/init/set_data.c |no clones | 1 monsters | 0 warnings
Fri Sep 1 22:53:16 EDT 2006
Hello cho,
ANALYSIS
lib/init/set_data.c functions
main (Begins at: 53 Ends at: 271)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |      88 |   *** | MONSTER |
LOC:          |     219 |    ** | Warning |
1 metric are OUT OF RANGE!
list_locations (Begins at: 274 Ends at: 283)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
list_mapsets (Begins at: 286 Ends at: 329)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
first_word (Begins at: 332 Ends at: 341)
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
hit_return (Begins at: 344 Ends at: 352)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
