[GRASS-QA] GRASS QA: cho | ./grass6/lib/gis/get_projname.c |no clones | 0 monsters | 0 warnings
Sat Sep 2 05:37:03 EDT 2006
Hello cho,
ANALYSIS
lib/gis/get_projname.c functions
G_ask_proj_name (Begins at: 23 Ends at: 91)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      37 |     * |         |
LOC:          |      69 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-02 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
