[GRASS-QA] GRASS QA: cho |
./grass6/visualization/nviz/src/do_zoom.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Sep 5 10:32:10 EDT 2006
Hello cho,
ANALYSIS
visualization/nviz/src/do_zoom.c functions
Nstart_zoom_cmd (Begins at: 42 Ends at: 204)
Complexity: | 12 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 41 | * | |
LOC: | 163 | * | |
metrics are OK
swap_os (Begins at: 211 Ends at: 226)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
Create_OS_Ctx (Begins at: 231 Ends at: 355)
ParamNBR: | 2 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 125 | * | |
metrics are OK
Destroy_OS_Ctx (Begins at: 361 Ends at: 393)
CalledNBR: | 11 | | OK |
LOC: | 33 | | OK |
metrics are OK
init_ctx (Begins at: 398 Ends at: 431)
Complexity: | 1 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 34 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
