[GRASS-QA] GRASS QA: cho | ./grass6/lib/form/form.c |no clones | 1 monsters | 1 warnings
Tue Sep 5 10:32:10 EDT 2006
Hello cho,
ANALYSIS
lib/form/form.c functions
close_form (Begins at: 38 Ends at: 43)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
reset_values (Begins at: 47 Ends at: 56)
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
set_value (Begins at: 59 Ends at: 82)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
submit (Begins at: 86 Ends at: 251)
Complexity:   |      17 |     * |         |
CalledNBR:    |      90 |   *** | MONSTER |
LOC:          |     166 |     * |         |
1 metric are OUT OF RANGE!
main (Begins at: 257 Ends at: 392)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      72 |    ** | Warning |
LOC:          |     136 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
