[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.univar2/main.c |no
	clones | 3 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Thu Sep  7 05:35:12 EDT 2006
Hello hamish,
ANALYSIS
raster/r.univar2/main.c functions
main (Begins at: 29 Ends at: 342)
Complexity:   |      42 |   *** | MONSTER |
CalledNBR:    |      90 |   *** | MONSTER |
LOC:          |     314 |   *** | MONSTER |
3 metric are OUT OF RANGE!
cmp_int (Begins at: 345 Ends at: 356)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
cmp_float (Begins at: 358 Ends at: 369)
LOC:          |      12 |       |      OK |
metrics are OK
cmp_double (Begins at: 371 Ends at: 382)
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-07 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
