[GRASS-QA] GRASS QA: hamish | ./grass6/lib/vector/Vlib/buffer.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Sep 11 04:41:21 EDT 2006
Hello hamish,
ANALYSIS
lib/vector/Vlib/buffer.c functions
vect (Begins at: 16 Ends at: 36)
Complexity: | 2 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 1 | | OK |
LOC: | 21 | | OK |
metrics are OK
find_cross (Begins at: 38 Ends at: 76)
Complexity: | 4 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
at least 1 values are close to an outlier please consider revising code
point_in_buf (Begins at: 82 Ends at: 115)
ParamNBR: | 4 | | OK |
LOC: | 34 | | OK |
metrics are OK
clean_parallel (Begins at: 117 Ends at: 234)
Complexity: | 14 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 118 | * | |
metrics are OK
parallel_line (Begins at: 236 Ends at: 316)
Complexity: | 7 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 81 | | OK |
metrics are OK
Vect_line_parallel (Begins at: 319 Ends at: 339)
Complexity: | 1 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 3 | | OK |
LOC: | 21 | | OK |
metrics are OK
Vect_line_buffer (Begins at: 342 Ends at: 437)
CalledNBR: | 26 | | OK |
LOC: | 96 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
