[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.carve/vect.c |1
clones ( vect.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Sep 13 09:53:39 EDT 2006
Hello brad,
ANALYSIS
raster/r.carve/vect.c functions
open_new_vect (Begins at: 27 Ends at: 35)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 9 | | OK |
metrics are OK
close_vect (Begins at: 41 Ends at: 50)
Complexity: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
open_new_vect
In raster/r.carve/vect.c clones of open_new_vect are:
vector/v.buffer/main.c stop
Threshold GRASS6 key metrics values at 2006-09-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
