[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.buffer/find_dist.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Sep 13 21:23:21 EDT 2006
Hello brad,
ANALYSIS
raster/r.buffer/find_dist.c functions
begin_distance (Begins at: 29 Ends at: 37)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
find_distances (Begins at: 46 Ends at: 100)
Complexity: | 7 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 55 | | OK |
metrics are OK
reset_distances (Begins at: 103 Ends at: 111)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
find_ll_distance_ncols (Begins at: 114 Ends at: 152)
CalledNBR: | 3 | | OK |
LOC: | 39 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
