[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.buffer/parse_dist.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Sep 13 21:23:21 EDT 2006
Hello brad,
ANALYSIS
raster/r.buffer/parse_dist.c functions
parse_distances (Begins at: 29 Ends at: 75)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 47 | | OK |
metrics are OK
cmp (Begins at: 77 Ends at: 82)
Complexity: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 6 | | OK |
metrics are OK
scan_dist (Begins at: 84 Ends at: 93)
Complexity: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
