[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.cats/main.c |no clones | 0 monsters | 0 warnings
Wed Sep 13 21:23:22 EDT 2006
Hello brad,
ANALYSIS
raster/r.cats/main.c functions
main (Begins at: 30 Ends at: 150)
Complexity:   |      16 |     * |         |
CalledNBR:    |      45 |     * |         |
LOC:          |     121 |     * |         |
metrics are OK
print_label (Begins at: 153 Ends at: 161)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
print_d_label (Begins at: 164 Ends at: 176)
CalledNBR:    |       5 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
scan_cats (Begins at: 179 Ends at: 193)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
scan_vals (Begins at: 196 Ends at: 203)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-13 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
