[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.buffer/process_row.c |no clones | 0 monsters | 0 warnings
Wed Sep 13 21:23:21 EDT 2006
Hello brad,
ANALYSIS
raster/r.buffer/process_row.c functions
process_row (Begins at: 25 Ends at: 59)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-13 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
