[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.coin/make_coin.c |1 clones ( make_coin.c )| 0 monsters | 0 warnings
Wed Sep 13 21:54:10 EDT 2006
Hello brad,
ANALYSIS
raster/r.coin/make_coin.c functions
make_coin (Begins at: 32 Ends at: 191)
Complexity:   |      16 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      42 |     * |         |
LOC:          |     160 |     * |         |
metrics are OK
cmp (Begins at: 193 Ends at: 202)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
collapse (Begins at: 205 Ends at: 223)
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  cmp
In raster/r.coin/make_coin.c clones of  cmp are:
	raster/r.random.cells/init.c  comp_array
Threshold GRASS6 key metrics values at 2006-09-13 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
