[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.clump/clump.c |no clones | 0 monsters | 1 warnings
Wed Sep 13 21:54:09 EDT 2006
Hello brad,
ANALYSIS
raster/r.clump/clump.c functions
clump (Begins at: 27 Ends at: 270)
Complexity:   |      25 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |     244 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
print_time (Begins at: 273 Ends at: 296)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-13 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
