[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.coin/prnt_entry.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Sep 13 21:54:10 EDT 2006
Hello brad,
ANALYSIS
raster/r.coin/prnt_entry.c functions
print_entry (Begins at: 31 Ends at: 67)
Complexity: | 10 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 37 | | OK |
metrics are OK
print_area (Begins at: 69 Ends at: 77)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
print_percent (Begins at: 79 Ends at: 84)
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
