[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.colors/main.c |1 clones ( main.c )| 2 monsters | 0 warnings
Fri Sep 15 04:46:51 EDT 2006
Hello brad,
ANALYSIS
raster/r.colors/main.c functions
rules_files (Begins at: 34 Ends at: 77)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
cmp_names (Begins at: 79 Ends at: 85)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
list_rules_files (Begins at: 87 Ends at: 131)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
main (Begins at: 133 Ends at: 345)
Complexity:   |      39 |   *** | MONSTER |
CalledNBR:    |     105 |   *** | MONSTER |
LOC:          |     213 |    ** | Warning |
2 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
  cmp_names
In raster/r.colors/main.c clones of  cmp_names are:
	lib/gis/datum.c  compare_table_names
Threshold GRASS6 key metrics values at 2006-09-15 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
