[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.cost/memory.c |3 clones ( main.c btree.c main.c memory.c )| 0 monsters | 0 warnings
Fri Sep 15 04:46:52 EDT 2006
Hello brad,
ANALYSIS
raster/r.cost/memory.c functions
allocate (Begins at: 42 Ends at: 84)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
release (Begins at: 86 Ends at: 102)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
get (Begins at: 104 Ends at: 121)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
give (Begins at: 123 Ends at: 133)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  release  get  allocate
In raster/r.cost/memory.c clones of  allocate are:
	raster/r.walk/memory.c  allocate
In raster/r.cost/memory.c clones of  release are:
	raster/r.walk/memory.c  release
In raster/r.cost/memory.c clones of  get are:
	raster/r.walk/memory.c  get
Threshold GRASS6 key metrics values at 2006-09-15 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
