[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.distance/report.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 15 05:53:37 EDT 2006
Hello brad,
ANALYSIS
raster/r.distance/report.c functions
report (Begins at: 21 Ends at: 79)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 59 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
