[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.distance/edges.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 15 05:53:36 EDT 2006
Hello brad,
ANALYSIS
raster/r.distance/edges.c functions
print_edge_info (Begins at: 21 Ends at: 28)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
find_edge_cells (Begins at: 30 Ends at: 96)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 67 | | OK |
metrics are OK
add_edge_cell (Begins at: 98 Ends at: 141)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 44 | | OK |
metrics are OK
init_edge_list (Begins at: 143 Ends at: 149)
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
cmp (Begins at: 151 Ends at: 155)
LOC: | 5 | | OK |
metrics are OK
sort_edge_list (Begins at: 157 Ends at: 161)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
