[GRASS-QA] GRASS QA: glynn |
./grass6/display/drivers/XDRIVER/Color_table.c |6 clones (
Color_table.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Sep 19 06:39:50 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/XDRIVER/Color_table.c functions
get_shifts (Begins at: 15 Ends at: 30)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 16 | | OK |
metrics are OK
get_rgb_shifts (Begins at: 32 Ends at: 39)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
find_color_gray (Begins at: 41 Ends at: 46)
ParamNBR: | 3 | | OK |
LOC: | 6 | | OK |
metrics are OK
find_color_indexed (Begins at: 48 Ends at: 51)
LOC: | 4 | | OK |
metrics are OK
find_color_rgb (Begins at: 53 Ends at: 60)
LOC: | 8 | | OK |
metrics are OK
find_color (Begins at: 62 Ends at: 80)
Complexity: | 9 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 19 | | OK |
metrics are OK
get_max_levels (Begins at: 82 Ends at: 102)
LOC: | 21 | | OK |
metrics are OK
get_fewer_levels (Begins at: 104 Ends at: 125)
Complexity: | 3 | | OK |
LOC: | 22 | | OK |
metrics are OK
try_get_colors (Begins at: 127 Ends at: 160)
Complexity: | 2 | | OK |
LOC: | 34 | | OK |
metrics are OK
try_get_grays (Begins at: 162 Ends at: 189)
ParamNBR: | 2 | | OK |
LOC: | 28 | | OK |
metrics are OK
ramp_colormap (Begins at: 191 Ends at: 214)
LOC: | 24 | | OK |
metrics are OK
init_color_table (Begins at: 216 Ends at: 309)
Complexity: | 21 | * | |
CalledNBR: | 15 | | OK |
LOC: | 94 | | OK |
metrics are OK
XD_lookup_color (Begins at: 312 Ends at: 336)
CalledNBR: | 2 | | OK |
LOC: | 25 | | OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
get_max_levels get_shifts try_get_colors find_color_rgb get_fewer_levels ramp_colormap
In display/drivers/XDRIVER/Color_table.c clones of ramp_colormap are:
visualization/xganim/Clr_table.c ramp_colormap
In display/drivers/XDRIVER/Color_table.c clones of get_max_levels are:
visualization/xganim/Clr_table.c get_max_levels
In display/drivers/XDRIVER/Color_table.c clones of get_fewer_levels are:
visualization/xganim/Clr_table.c get_fewer_levels
In display/drivers/XDRIVER/Color_table.c clones of find_color_rgb are:
visualization/xganim/Clr_table.c find_color_rgb
In display/drivers/XDRIVER/Color_table.c clones of try_get_colors are:
visualization/xganim/Clr_table.c try_get_colors
In display/drivers/XDRIVER/Color_table.c clones of get_shifts are:
visualization/xganim/Clr_table.c get_shifts
Threshold GRASS6 key metrics values at 2006-09-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
