[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_io.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Sep 19 06:39:51 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/com_io.c functions
init_transport (Begins at: 161 Ends at: 177)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 17 | | OK |
metrics are OK
R_open_driver (Begins at: 179 Ends at: 183)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 5 | | OK |
metrics are OK
R__open_quiet (Begins at: 185 Ends at: 189)
LOC: | 5 | | OK |
metrics are OK
R_stabilize (Begins at: 191 Ends at: 194)
LOC: | 4 | | OK |
metrics are OK
R_kill_driver (Begins at: 196 Ends at: 199)
LOC: | 4 | | OK |
metrics are OK
R_close_driver (Begins at: 201 Ends at: 204)
LOC: | 4 | | OK |
metrics are OK
R_release_driver (Begins at: 206 Ends at: 209)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
