[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Color.c |1 clones
	( Color_table.c main.c graphics.c graphics.c Color.c )| 0
	monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Tue Sep 19 06:39:51 EDT 2006
Hello glynn,
ANALYSIS
lib/driver/Color.c functions
DRV_lookup_color (Begins at: 5 Ends at: 10)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
DRV_color (Begins at: 12 Ends at: 16)
ParamNBR:     |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
COM_Color (Begins at: 18 Ends at: 21)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
COM_Color_RGB (Begins at: 23 Ends at: 26)
LOC:          |       4 |       |      OK |
metrics are OK
COM_Standard_color (Begins at: 28 Ends at: 31)
LOC:          |       4 |       |      OK |
metrics are OK
LIB_get_color_index (Begins at: 33 Ends at: 36)
LOC:          |       4 |       |      OK |
metrics are OK
LIB_get_color_index_array (Begins at: 38 Ends at: 41)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In lib/driver/Color.c clones of  LIB_get_color_index_array are:
	display/drivers/lib/Color.c  LIB_get_color_index_array
Threshold GRASS6 key metrics values at 2006-09-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
