[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Color_table.c |3 clones ( main.c graphics.c graphics.c graphics.c Color_table.c )| 0 monsters | 0 warnings
Tue Sep 19 07:23:19 EDT 2006
Hello glynn,
ANALYSIS
lib/pngdriver/Color_table.c functions
set_color (Begins at: 11 Ends at: 17)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
init_colors_rgb (Begins at: 19 Ends at: 22)
ParamNBR:     |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
init_colors_indexed (Begins at: 24 Ends at: 65)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
init_color_table (Begins at: 67 Ends at: 83)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
get_color_rgb (Begins at: 85 Ends at: 88)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
get_color_indexed (Begins at: 90 Ends at: 96)
LOC:          |       7 |       |      OK |
metrics are OK
PNG_lookup_color (Begins at: 98 Ends at: 103)
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  PNG_Color_table_float  PNG_reset_color  init_colors_indexed
In lib/pngdriver/Color_table.c clones of  PNG_Color_table_float are:
	display/drivers/PNG/Color_table.c  PNG_Color_table_float
In lib/pngdriver/Color_table.c clones of  PNG_reset_color are:
	display/drivers/PNG/Color_table.c  PNG_reset_color
In lib/pngdriver/Color_table.c clones of  init_colors_indexed are:
	display/drivers/PNG/Color_table.c  init_colors_indexed
Threshold GRASS6 key metrics values at 2006-09-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
