[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.in.dxf/write_vect.c |no clones | 0 monsters | 0 warnings
Wed Sep 20 16:22:39 EDT 2006
Hello markus,
ANALYSIS
vector/v.in.dxf/write_vect.c functions
write_vect (Begins at: 14 Ends at: 71)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
write_done (Begins at: 73 Ends at: 117)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
get_field_cat (Begins at: 119 Ends at: 219)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |     101 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-20 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
