[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.to.db/parse.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Sep 21 09:49:10 EDT 2006
Hello markus,
ANALYSIS
vector/v.to.db/parse.c functions
parse_command_line (Begins at: 13 Ends at: 159)
Complexity: | 12 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 42 | * | |
LOC: | 147 | * | |
metrics are OK
parse_units (Begins at: 161 Ends at: 173)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 13 | | OK |
metrics are OK
parse_option (Begins at: 175 Ends at: 192)
CalledNBR: | 11 | | OK |
LOC: | 18 | | OK |
metrics are OK
match (Begins at: 195 Ends at: 203)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
