[GRASS-QA] GRASS QA: jachym | ./grass6/lib/gis/parser.c |1 clones (
parser.c )| 2 monsters | 4 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Sep 23 15:06:23 EDT 2006
Hello jachym,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 200 Ends at: 216)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_define_flag (Begins at: 219 Ends at: 267)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 49 | | OK |
metrics are OK
G_define_option (Begins at: 270 Ends at: 340)
LOC: | 71 | | OK |
metrics are OK
G_define_standard_option (Begins at: 343 Ends at: 520)
Complexity: | 22 | * | |
CalledNBR: | 22 | | OK |
LOC: | 178 | * | |
metrics are OK
G_define_module (Begins at: 523 Ends at: 557)
CalledNBR: | 1 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_parser (Begins at: 559 Ends at: 820)
Complexity: | 36 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 70 | ** | Warning |
LOC: | 262 | *** | MONSTER |
1 metric are OUT OF RANGE!
uses_new_gisprompt (Begins at: 823 Ends at: 868)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_usage (Begins at: 870 Ends at: 1044)
Complexity: | 32 | ** | Warning |
CalledNBR: | 53 | * | |
LOC: | 175 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1046 Ends at: 1062)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 1064 Ends at: 1268)
Complexity: | 26 | ** | Warning |
CalledNBR: | 65 | ** | Warning |
LOC: | 205 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
G_usage_html (Begins at: 1270 Ends at: 1501)
Complexity: | 41 | *** | MONSTER |
CalledNBR: | 80 | *** | MONSTER |
LOC: | 232 | ** | Warning |
generate_tcl (Begins at: 1503 Ends at: 1575)
Complexity: | 9 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 73 | | OK |
metrics are OK
G_gui (Begins at: 1578 Ends at: 1607)
CalledNBR: | 8 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_tcltk (Begins at: 1610 Ends at: 1625)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1627 Ends at: 1656)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1658 Ends at: 1671)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1673 Ends at: 1700)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1705 Ends at: 1714)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1716 Ends at: 1776)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 1778 Ends at: 1815)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 1817 Ends at: 1859)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 1861 Ends at: 1927)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 1929 Ends at: 1969)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 1971 Ends at: 1998)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 2000 Ends at: 2023)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 2025 Ends at: 2088)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 2090 Ends at: 2128)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 2131 Ends at: 2187)
Complexity: | 11 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2189 Ends at: 2217)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2219 Ends at: 2227)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2229 Ends at: 2319)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2321 Ends at: 2351)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2353 Ends at: 2398)
CalledNBR: | 20 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_recreate_command (Begins at: 2400 Ends at: 2502)
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
interactive_flag
In lib/gis/parser.c clones of interactive_flag are:
lib/gis/rm_colr.c G_remove_colr
Threshold GRASS6 key metrics values at 2006-09-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
