[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/verbose.c |no clones | 0 monsters | 0 warnings
Sun Sep 24 04:46:34 EDT 2006
Hello brad,
ANALYSIS
lib/gis/verbose.c functions
G_verbose (Begins at: 36 Ends at: 52)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_verbose_max (Begins at: 59 Ends at: 62)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_verbose_min (Begins at: 69 Ends at: 72)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-24 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
