[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.le/r.le.patch/patch.c |no clones | 5 monsters | 4 warnings
Sun Sep 24 04:46:35 EDT 2006
Hello brad,
ANALYSIS
raster/r.le/r.le.patch/patch.c functions
df_patch (Begins at: 41 Ends at: 301)
Complexity:   |      67 |   *** | MONSTER |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |     106 |   *** | MONSTER |
LOC:          |     261 |   *** | MONSTER |
3 metric are OUT OF RANGE!
df_att (Begins at: 309 Ends at: 348)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
save_att (Begins at: 356 Ends at: 431)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      10 |       |      OK |
LOC:          |      76 |       |      OK |
at least 1 values are close to an outlier please consider revising code
df_core (Begins at: 439 Ends at: 552)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |     114 |     * |         |
metrics are OK
save_core (Begins at: 554 Ends at: 687)
Complexity:   |      16 |     * |         |
ParamNBR:     |      13 |   *** | MONSTER |
LOC:          |     134 |     * |         |
1 metric are OUT OF RANGE!
df_size (Begins at: 695 Ends at: 774)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
save_size (Begins at: 776 Ends at: 876)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      13 |       |      OK |
LOC:          |     101 |       |      OK |
df_shape (Begins at: 878 Ends at: 1044)
Complexity:   |      20 |     * |         |
CalledNBR:    |      37 |     * |         |
LOC:          |     167 |     * |         |
metrics are OK
save_shape (Begins at: 1046 Ends at: 1292)
Complexity:   |      30 |    ** | Warning |
ParamNBR:     |      19 |   *** | MONSTER |
CalledNBR:    |      36 |     * |         |
LOC:          |     247 |    ** | Warning |
df_boundary (Begins at: 1294 Ends at: 1355)
Complexity:   |       5 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
df_perim (Begins at: 1357 Ends at: 1462)
LOC:          |     106 |       |      OK |
metrics are OK
mv_patch (Begins at: 1464 Ends at: 1510)
CalledNBR:    |       8 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
recl_coh (Begins at: 1512 Ends at: 1535)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
in_group (Begins at: 1537 Ends at: 1593)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
index_coh (Begins at: 1595 Ends at: 1620)
LOC:          |      26 |       |      OK |
metrics are OK
m_att (Begins at: 1622 Ends at: 1753)
Complexity:   |      21 |     * |         |
CalledNBR:    |       4 |       |      OK |
LOC:          |     132 |     * |         |
metrics are OK
m_size (Begins at: 1760 Ends at: 1888)
Complexity:   |      19 |     * |         |
LOC:          |     129 |     * |         |
metrics are OK
m_core (Begins at: 1890 Ends at: 2074)
Complexity:   |      32 |    ** | Warning |
CalledNBR:    |       7 |       |      OK |
LOC:          |     185 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
m_shape (Begins at: 2076 Ends at: 2209)
Complexity:   |      24 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |     134 |     * |         |
metrics are OK
m_boundary (Begins at: 2211 Ends at: 2294)
CalledNBR:    |       2 |       |      OK |
LOC:          |      84 |       |      OK |
metrics are OK
m_perim (Begins at: 2296 Ends at: 2386)
LOC:          |      91 |       |      OK |
metrics are OK
eu_d (Begins at: 2390 Ends at: 2394)
Complexity:   |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-24 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
