[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.out.vtk/errorHandling.c |no clones | 0 monsters | 0 warnings
Sun Sep 24 12:30:41 EDT 2006
Hello soeren,
ANALYSIS
raster3d/r3.out.vtk/errorHandling.c functions
fatal_error (Begins at: 35 Ends at: 43)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
CloseInputRasterMap (Begins at: 48 Ends at: 58)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
close_input_raster3d_map (Begins at: 63 Ends at: 75)
LOC:          |      13 |       |      OK |
metrics are OK
release_input_maps_struct (Begins at: 80 Ends at: 110)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-24 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
