[GRASS-QA] GRASS QA: soeren |
./grass6/raster3d/base/mask_functions.c |1 clones (
mask_functions.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Sep 24 12:30:41 EDT 2006
Hello soeren,
ANALYSIS
raster3d/base/mask_functions.c functions
init_d_mask_rules (Begins at: 30 Ends at: 33)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
add_d_mask_rule (Begins at: 36 Ends at: 46)
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 11 | | OK |
metrics are OK
mask_d_select (Begins at: 49 Ends at: 60)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
mask_match_d_interval (Begins at: 63 Ends at: 72)
LOC: | 10 | | OK |
metrics are OK
parse_d_mask_rule (Begins at: 75 Ends at: 104)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 30 | | OK |
metrics are OK
parse_vallist (Begins at: 107 Ends at: 137)
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
mask_d_select
In raster3d/base/mask_functions.c clones of mask_d_select are:
raster/r.null/mask.c mask_d_select
Threshold GRASS6 key metrics values at 2006-09-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
