[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.average/main.c |no clones | 0 monsters | 1 warnings
Sun Sep 24 13:57:04 EDT 2006
Hello jachym,
ANALYSIS
raster/r.average/main.c functions
main (Begins at: 34 Ends at: 159)
Complexity:   |      16 |     * |         |
CalledNBR:    |      63 |    ** | Warning |
LOC:          |     126 |     * |         |
at least 1 values are close to an outlier please consider revising code
out (Begins at: 162 Ends at: 178)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       7 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-24 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
