[GRASS-QA] GRASS QA: soeren | ./grass6/raster/r.what/die.c |1
clones ( raster.c die.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Sep 24 15:36:35 EDT 2006
Hello soeren,
ANALYSIS
raster/r.what/die.c functions
die (Begins at: 4 Ends at: 12)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
die
In raster/r.what/die.c clones of die are:
raster/r.digit/create_map.c create_map
display/d.mon/cmd/main.c run
Threshold GRASS6 key metrics values at 2006-09-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
